Nuvoton’s Single-Chip Smart Buzzer IC ‘Goes Beyond the Beep’
The new smart buzzer control chip enables voice, music, and sound effects via a piezo element with minimal external components.
News November 16, 2026 by Duane Benson
Nuvoton recently introduced the NSP2340BA24E series smart buzzer control chips to allow complex audio functionality from a microcontroller (MCU). The new part communicates with an MCU over I2C or UART protocols to deliver tone, voice, melody, and audio special effects from a simple piezo element.
The chip contains memory to hold up to 315 seconds of custom sounds. It also includes circuitry to drive piezo elements directly at up to 24 V. Once the Nuvoton chip is loaded with audio snippets, the MCU only needs to send a command to deliver audio.
NSP2340BA24E
The new Nuvoton NSP2340BA24E smart buzzer controllers let an MCU use a simple piezo buzzer to deliver complex audio effects.
By directly managing power and matching a piezo buzzer's audio characteristics, the chip can replace systems that require multiple parts. It can perform the functionality of an audio player, amplifier, discrete flash memory, and boost power supply all in one. This enables design updates that deliver greater audio notification functionality with a smaller printed circuit board footprint and lower manufacturing and selling costs.
Key Features of the New Smart Buzzer
The series includes three variants, all equal in functionality except for the amount of included flash memory. The NSP2080BA24E includes flash for up to 72 seconds of NSP-encoded audio, 18 seconds of 16-kHz NM4-encoded audio, or 16 seconds of 24-kHz NM4. The NSP2170BA24E can store 133 seconds of NSP-encoded audio, 33 seconds of 16-kHz NM4-encoded audio, or 22 seconds of 24-kHz NM4. The third variant, the NSP2340BA24E, can store 315 seconds of NSP-encoded audio, 78 seconds of 16-kHz NM4-encoded audio, or 69 seconds of 24-kHz NM4.
The operating voltage for the three chips (datasheet linked) ranges from 2.0 V to 5.5 V; operating current is 20 mA, and standby current is less than 3 μA. It supports automatic shutdown and wake-up, as well as over-temperature and overcurrent protection. Audio gain is set via a single external fixed or variable resistor, and piezo voltage is set through a two-bit binary value on two input pins.
Typical application circuit connecting to a host uC by an I2C interface.
The chip communicates with a host MCU via I2C, two-wire UART, or a simplified two-wire protocol. The chips can be programmed in-circuit to update or add audio. It is manufactured to an industrial operating temperature range of -40°C to 85°C. The parts all come in a 4.4 mm x 9.7 mm TSSOP28 package with an underside thermal pad.
Audio comes from a built-in class AB amplifier that drives a piezo buzzer element. A built-in boost supply can power 10 V, 12 V, 18 V, and 24 V piezo elements without external high-voltage components.
Changing Needs for Audio Notifications
A buzzer may seem like an unlikely target for adding intelligence. However, today’s devices need far more flexibility than a simple buzz. Adding the new Nuvoton control chip to a piezo element adds a host of capabilities. The smart buzzer can deliver simple buzzes and tones, as well as rich audio, from a single IC. It can store multiple specific messages such as “system ready”, “battery low”, or “good morning”, as well as custom music and special-effect sounds.
Development Board
Nuvoton offers the SB2340-HN30A development platform. The board includes the NSP2340BA24E chip, five user keys/buttons, a gain-setting variable resistor, and a GPIO header. It’s powered by USB-C and can power piezo elements from 10 V to 24 V. The development board gives users access to a playlist editor and project tutorials.
SB2340-HN30A development board
SB2340-HN30A development board.
The chips and development board are available now through Nuvoton distribution channels.
All images used courtesy of Nuvoton.
