3 Hardware Highlights From Qualcomm’s Snapdragon Summit 2026
The Snapdragon 8 Elite Extreme Gen 6 and 8 Elite Gen 6 are the first mobile SoCs to break the 5 GHz barrier, while Snapdragon Sound Elite Gen 2 targets camera-equipped AI wearables.
News 6 hours ago by Luke James
Qualcomm used its Snapdragon Summit 2026 event in Maui, Hawaii, to announce three new products: the Snapdragon 8 Elite Extreme Gen 6 and Snapdragon 8 Elite Gen 6 mobile platforms, and the Snapdragon Sound Elite Gen 2 audio processor for AI-driven wearables. The two mobile SoCs are built on TSMC's 2-nm N2P process, making them the first mobile chips to use a gate-all-around FET (GAAFET) transistor architecture, and both push CPU clock speeds past 5 GHz for the first time in a smartphone chipset.
The summit marked Qualcomm's most aggressive push into on-device AI, with the company framing all three products around what it calls the "agentic AI age," its term for AI agents that can act autonomously on the user's behalf.
Two Tiers of Flagship Silicon
Both mobile platforms share the same CPU architecture: two Oryon V4 Prime cores running at 5.0 GHz and six Oryon V4 Performance cores at 4.0 GHz, backed by 16 MB of Oryon Flex Cache. The GPU is a rearchitected Adreno design, and both chips pair it with a Hexagon NPU featuring 12 scalar cores, eight vector cores, one tensor core, and a new Element Accelerator optimized for transformer workloads used by LLMs.
The differences between the two chips are a matter of degree, not architecture. The Elite Extreme Gen 6 claims a 13% CPU performance uplift over the previous generation with a 37% reduction in power consumption, while the standard Elite Gen 6 posts a 10% CPU improvement at the same efficiency gains. On the GPU side, the Extreme variant delivers 44% higher graphics performance with 40% better power efficiency, compared with 35% and 40% for the standard model, respectively.
The Snapdragon 8 Elite Extreme Gen 6 and Snapdragon 8 Elite Gen 6 mobile SoCs
The Snapdragon 8 Elite Extreme Gen 6 and Snapdragon 8 Elite Gen 6 mobile SoCs.
The Extreme variant also gets exclusive features. Its Adreno GPU includes dedicated AI matrix cores and 18 MB of high-performance memory, enabling a feature Qualcomm calls Adreno Neural Fusion, an AI-driven super-resolution and frame-generation pipeline that the company says reduces rendering power by up to 40%. The Extreme's Hexagon NPU carries 50% more shared memory than the standard chip, supporting on-device inference of mixture-of-experts models with 30 billion or more parameters and 32K context windows.
Both chips integrate the Snapdragon X105 5G modem with 3GPP Release 19 support, offering peak download speeds of 14.8 Gbps and uplink at 4.2 Gbps. Connectivity includes Wi-Fi 8 via the FastConnect 8800 at up to 11.6 Gbps, Bluetooth 6.0 with High Data Throughput, and Ultra-Wideband support. Memory options span LPDDR5X and LPDDR6 at up to 5,300 MHz, with UFS 5.0 storage.
The imaging system uses a triple 20-bit Spectra AI ISP supporting up to 320 MP single-camera or triple 64 MP configurations, while the Extreme model adds 8K video capture at 60 fps and 4K slow-motion at 240 fps, along with hardware support for the APV video codec. The standard model caps out at 8K30 and 1080p at 480 fps.
Qualcomm shared benchmark results from a reference device running the Extreme variant: 4,291 in Geekbench 6 single-core, 12,686 multi-core, 5.57 million on AnTuTu v12, and 32.56 fps in 3DMark Steel Nomad Light. OEM partners confirmed for early devices include Xiaomi, Honor, iQOO, Motorola, OnePlus, and RedMagic, with Motorola's Signature 27 announced as one of the first handsets to carry the Extreme chip.
An Audio Platform for AI Wearables
Alongside the mobile SoCs, Qualcomm introduced the Snapdragon Sound Elite Gen 2, an audio platform targeting a new category of intelligent wearables that goes beyond traditional earbuds and headphones. The platform doubles on-device AI processing capability compared to its predecessor while cutting power consumption by 40% in a 30% smaller footprint.
The Snapdragon Sound Elite Gen 2
The Snapdragon Sound Elite Gen 2.
The most notable addition is camera support. Snapdragon Sound Elite Gen 2 can process input from onboard vision sensors, feeding contextual environmental data to personal AI agents running on the device. Qualcomm envisions this powering camera-equipped earbuds, audio glasses, and other multimodal wearables that combine audio, visual, and voice interaction.
The platform includes integrated micro-power Wi-Fi 6E for direct cloud connectivity, letting devices handle complex AI queries without routing through a paired smartphone, along with aptX Lossless playback, XPAN ultra-range Bluetooth connectivity, and Qualcomm's 5th-generation adaptive noise cancellation.
All images used courtesy of Qualcomm.
