Newhaven Display IPS TFT LCD Modules | New Product Brief
Newhaven Display IPS TFT LCD Modules are ideal for applications like wearables, handhelds, test equipment, and more.
Newhaven Display 2.8-inch IPS TFT LCD Display modules offer consistent, accurate color from all viewing angles, and are ideal for use in applications ranging from wearables and handhelds to scales and test equipment. The display is 240 x 320 pixels, can produce 262K colors, and uses high brightness LED backlight. It also has a built-in ST7789Vi controller supporting an 8-bit or 16-bit parallel interface to the host processor.
Display modules are available with or without a touch panel, with touch panel options including resistive or capacitive touch. Newhaven Display 2.8-inch IPS TFT LCD Display modules operate from a 3V supply, are very thin, and have an FFC ZIF I/O connector for easy integration into low-profile devices.
- 2.8-inch IPS display
- Resolution: 240 x 320 pixels
- 262K colors
- Built-in ST7789Vi controller
- 8-bit or 16-bit parallel MPU interface
- Optional capacitive or resistive touch panel
- Capacitive touch panel: built-in FT5426 controller
- 3.0V power supply
- Module thickness: 2.39mm to 3.99mm
- FFC ZIF I/O connection
