BOSCH BMP585 Barometric Pressure Sensor | New Product Brief
The Bosch BMP585 Barometric Pressure Sensor is an innovative and reliable solution for pressure sensing applications. Watch and learn all about their features, specs, applications, and more!
The Bosch BMP585 Barometric Pressure Sensor, available from Mouser Electronics, is an innovative and reliable solution for pressure sensing applications. It sets a high standard with its exceptional performance and features.
The sensor boasts an absolute accuracy of plus or minus 50 Pascals, ensuring precise pressure measurements. It also has a temperature coefficient offset of plus or minus 0.5 Pascals per degree Kelvin, further enhancing its accuracy and stability. The BMP585 can detect height changes as small as a few centimeters, making it highly sensitive and suitable for various applications. Its operational pressure range spans from 300 to 1250 Hectopascals.
Operating voltages for the BMP585 range from 1.08 to 3.6 Volts for the IOs and 1.71 to 3.6 Volts for the primary supply. This flexibility in voltage requirements allows for easy integration into different systems and power sources.
The sensor is designed with a gel-filled cavity, providing robust protection against water, chemicals, and other liquids. This ensures its durability and reliability even in harsh environments.
With its compact footprint, the Bosch BMP585 Barometric Pressure Sensor offers a convenient single-package solution for various applications, including smartwatches, wearables, home appliances, and more. Its high performance, accuracy, and robust design make it an industry-leading choice for pressure sensing requirements.
Bosch BMP585 Barometric Pressure Sensor excels in reliability and performance. It offers precise and accurate pressure measurements, sensitivity to small height changes, and robust protection against liquids. With its compact form factor, it is a versatile solution suitable for a wide range of applications.
