Amphenol Advanced Sensors Pipe Clip Temperature Sensors | New Product Brief
Amphenol Advanced Sensors JS8741 are high sensitivity clip-on temperature sensors used to monitor fluid or gas temperature in pipes or tubing.
Amphenol Advanced Sensors JS8741 are high sensitivity clip-on temperature sensors used to monitor fluid or gas temperature in pipes or tubing. Sensors are available with initial resistance values of 2.7, 10.0, or 30.0kΩ, are rated for operation from -40°C to +120°C, and have a fast response time.
The lightweight and compact design features a quick-mount spring-loaded galvanized steel clip for easy installation on pipes from 15mm to 18mm, and gray polyamide housing with a VW75174 approved integrated connecter and locking mechanism. Amphenol Advanced Sensors JS8741 Pipe Clip Temperature Sensors are IP57 rated and ideal for monitoring engine or battery pack coolant temperature, process flows, HVAC water and refrigeration, and home appliances.
- Resistance at 25°C: 2.7kΩ, 10.0kΩ, or 30.0kΩ
- Operating Temperature: -40°C to +120°C
- Response Time: ~20s mounted on a metallic pipe
- Weight: 10g
- Pipe Diameters: 15mm to 18mm
- Connector: Integrated with CPA locking, VW75174 approved
