- Heat Pump Working Principle
- Market Trends and Heat Pump Types
- Single- and Three-Phase Heat Pumps
- Recommended Products
- Development Tools and Resources
Guide Overview
Download this guide to learn everything you need to know about heat pumps and how to select a right solution to build more energy efficient, reliable, and compact systems.
Heat pumps are gaining traction because they are a proven solution for providing sustainable heating powered by low-emissions electricity.
In this guide, learn everything you need to know about heat pumps. It examines how heat pumps work, the key market types driving them, and discusses the different types of heat pumps. Also covered are single- and three-phase heat pump system archtectures and an extensive compilation of recommended products details for the PFCs, inverters, and other system blocks. The guide also features how Intelligent Power Modules (IPMs) play a significant role in delivering higher efficiency, smaller footprint and higher power density, resulting in lower total system cost.
