Learn how to reduce system losses by up to 50% and optimize system size and costs using silicon carbide solutions from Wolfspeed. These advanced power devices will enable you to meet demanding global efficiency standards, including the new EU requirement to meet the IE4 efficiency standard for all motors from 75kW to 230 kW.
In this webinar, you’ll learn how to create rugged and reliable systems with best-in-class power density, performance, and efficiency with:
Up to 50% less losses system-wide
Optimize system costs and size
Improve motor drive efficiency by up to 2.6%
Superior thermal performance
Improved energy density
Analyze return on investment
Switching from traditional silicon IGBTs to Wolfspeed silicon carbide power devices can increase an industrial motor drive’s efficiency while reducing overall unit size and cost of ownership. For example, upgrading the PFC and inverter in a 3-phase 25 kW compressor with Six-Pack Wolfspeed WolfPACK™ modules enabled designers to use 77% smaller heat sinks in addition to enhanced efficiency. The webinar will also highlight Wolfspeed’s time-saving reference designs, which include application notes, user guides, and design files.
by Omron
