In this circuit, three resistors receive the same amount of voltage (24 volts) from a single source. Calculate the amount of current “drawn” by each resistor, as well as the amount of power dissipated by each resistor:
I1 Ω = 24 amps
I2 Ω = 12 amps
I3 Ω = 8 amps
P1 Ω = 576 watts
P2 Ω = 288 watts
P3 Ω = 192 watts
The answers to this question may seem paradoxical to students: the lowest value of resistor dissipates the greatest power. Math does not lie, though.
Another purpose of this question is to instill in students’ minds the concept of components in a simple parallel circuit all sharing the same amount of voltage.
Challenge your students to recognize any mathematical patterns in the respective currents and power dissipations. What can be said, mathematically, about the current drawn by the 2 Ω resistor versus the 1 Ω resistor, for example?
You might want to mention that in electrical parlance, a “heavy” load is one that draws a large amount of current, and thus has a large resistance. This circuit, which shows how the lowest resistance in a parallel circuit consumes the most power, gives practical support to the term “heavy” used to describe loads.
What will happen to the brightness of the light bulb if the switch in this circuit is suddenly closed?
Ideally, there will be no change whatsoever in the light bulb’s brightness when the switch is closed, because voltage sources are supposed to maintain constant voltage output regardless of loading. As you might have supposed, though, the additional current “drawn” by the resistor when the switch is closed might actually cause the lamp to dim slightly, due to the battery voltage “sagging” under the additional load. If the battery is well oversized for the application, though, the degree of voltage “sag” will be inconsequential.
This question illustrates a disparity between the ideal conditions generally assumed for theoretical calculations, and those conditions encountered in real life. Truly, it is the purpose of a voltage source to maintain a constant output voltage regardless of load (current drawn from it), but in real life this is nearly impossible. Most voltage sources exhibit some degree of “sag” in their output over a range of load currents, some worse than others.
In this example, it is impossible to tell how much the voltage source’s output will “sag” when the switch is closed, because we have no idea of what the resistor’s current draw will be compared to that of the light bulb, or what the voltage source’s rated output current is. All we can say is that theoretically there will be no effect from closing the switch, but that in real life there will be some degree of dimming when the switch is closed.
Don’t just sit there! Build something!! |
Avoid very high and very low resistor values, to avoid measurement errors caused by meter “loading”. I recommend resistors between 1 kΩ and 100 kΩ, unless, of course, the purpose of the circuit is to illustrate the effects of meter loading!
Let the electrons themselves give you the answers to your own “practice problems”!
The equation for calculating total resistance in a parallel circuit (for any number of parallel resistances) is sometimes written like this:
$$R_{total} = (R_1^{-1} + R_2^{-1} + ...R_n^{-1})^{-1}$$
Re-write this equation in such a way that it no longer contains any exponents.
$$R_{total} = \frac {1}{\frac{1}{R_1}+\frac{1}{R_2}+...\frac{1}{R_n}}$$
This question is an exercise in basic algebra, specifically the meaning of negative exponents.
Manipulate this equation to solve for resistor value R1, given the values of R2 and Rparallel:
$$R_{parallel} = \frac {R_1R_2}{R_1+R_2}$$
Then, give an example of a practical situation where you might use this new equation.
$$R_1 = \frac {R_2R_{parallel}}{R_2-R_{parallel}}$$
I’ll let you figure out a situation where this equation would be useful!
This question is really nothing more than an exercise in algebraic manipulation.
The formula for calculating total resistance of three parallel-connected resistors is as follows:
$$R = \frac {1}{\frac{1}{R_1}+\frac{1}{R_2}+\frac{1}{R_3}}$$
Algebraically manipulate this equation to solve for one of the parallel resistances (R1) in terms of the other two parallel resistances (R2 and R3) and the total resistance (R). In other words, write a formula that solves for R1 in terms of all the other variables.
$$R_1 = \frac {1}{\frac{1}{R}-(\frac{1}{R_2}+\frac{1}{R_3})} \ \ \ \ \ \ \ \ \ or \ \ \ \ \ \ \ \ \ R_1 = \frac {1}{\frac{1}{R}-\frac{1}{R_2}-\frac{1}{R_3}}$$
This question is nothing more than practice algebraically manipulating equations. Ask your students to show you how they solved it, and how the two given answers are equivalent.
Identify which of these circuits is a parallel circuit (there may be more than one shown!):
Circuits D and E are parallel circuits.
Circuit B is a series-parallel circuit as it includes resistors in series and in parallel.
The purpose of this question is to get students to identify what distinguishing characteristic uniquely identifies a circuit as being “parallel.” Once this has been identified, there are several conclusions which may be deduced (regarding voltage drops, currents, resistances, etc.).
Some students may have difficulty distinguishing that circuit E is a parallel circuit, but it is!
Determine the amount of voltage impressed across each resistor in this circuit:
Hint: locate all the points in this circuit that are electrically common to one another!
Each resistor has 15 volts across it in this circuit.
The hint suggesting identification of electrically common points is critical to students’ understanding of parallel circuits. Once they see that there is no difference (as far as voltage is concerned) between the top of one resistor, the top of the other, or the top of the battery (and likewise for all the bottom connections), it should become clearly evident why voltage must be equal across these three components.
According to Ohm’s Law, how much current goes through each of the two resistors in this circuit?
Draw the paths of all currents in this circuit.
IR(2.2k) = 10.91 mA
IR(4.7k) = 5.11 mA
Follow-up question: how much total current does the battery supply to the circuit, given these individual resistor currents?
A key element to this question is the plotting of currents. Students need to see how individual resistor currents graphically relate to the total source current in a parallel circuit, because this has direct bearing on the calculation of total current, and also to an understanding of total resistance in parallel circuits.
Qualitatively compare the voltage and current for each of the three light bulbs in this circuit (assume the three light bulbs are absolutely identical):
The voltage dropped across each of the lights bulbs is guaranteed to be equal. The current through each of the light bulbs, in this particular case (with identical bulbs), happens to be equal.
Here, the important principles of voltage and current in a parallel circuit are highlighted. This question serves to further define, in practical ways, what the term “parallel” really means.
An important lesson of this question is the distinction between measurements which are guaranteed to be equal versus measurements which just happen to be equal for a given selection of components.
Calculate the total amount of current that the battery must supply to this parallel circuit:
Now, using Ohm’s Law, calculate total resistance (Rtotal) from total (source) voltage Vtotal and total (source) current Itotal.
Itotal = 40.0 mA
Rtotal = 250 Ω
Follow-up question: without appealing to Ohm’s Law, explain why the total resistance is one-half as much as either of the individual resistances.
While some students seem able to immediately grasp the concept of parallel resistances diminishing in (total) value, it is worthwhile to approach it from an Ohm’s Law perspective as well to give other students a more formal rationale for this effect.
Suppose I connect two resistors in parallel with one another, like this:
How much electrical resistance would you expect an ohmmeter to indicate if it were connected across the combination of these two parallel-connected resistors?
Explain the reasoning behind your answer, and try to formulate a generalization for all combinations of parallel resistances.
Follow-up question: how much resistance would you expect the ohmmeter to register if there were three similarly-sized resistors connected in parallel instead of two? What if there were four resistors?
The concept of parallel (total) resistance, in relation to individual resistances, often confuses new students. Be sure to allow plenty of discussion time to work through the conceptual difficulties with them.
There are two well-known formulae for calculating the total resistance of parallel-connected resistances. One of these works only for two resistances, while the other works for any number of parallel resistances. Write these two formulae, and give examples of their use.
$$R_{parallel} = \frac{R_1R_2}{R_1+R_2}$$
$$R_{parallel} = \frac{1}{\frac{1}{R_1}+\frac{1}{R_2}+... \frac{1}{R_n}}$$
Although I typically use the lower formula exclusively in my teaching, the upper formula is often useful for situations where a calculator is not handy, and you must estimate parallel resistance.
A quantity often useful in electric circuit analysis is conductance, defined as the reciprocal of resistance:
$$G= \frac{1}{R}$$
In a series circuit, resistance increases and conductance decreases with the addition of more resistors:
Describe what happens to total resistance and total conductance with the addition of parallel resistors:
When successive resistors are connected in parallel, total resistance decreases while total conductance increases.
Follow-up question: what is the exact formula that describes total conductance in a network of parallel conductances?
$$G_{total}=???$$
Once students recognize the mathematical relationship between resistance and conductance \((G= \frac{1}{R})\), and they realize that parallel conductances add just like series resistances add, it is but a short exercise in algebra to develop the parallel resistance formula \((R_{parallel} = \frac{1}{\frac{1}{R_1}+\frac{1}{R_2}+... \frac{1}{R_n}})\).
Explain, step by step, how to calculate the amount of current (I) that will go through each resistor in this parallel circuit, and also the voltage (V) dropped by each resistor:
Follow-up question: trace the direction of current through all three resistors as well as the power supply (battery symbol). Compare these directions with the polarity of their shared voltage. Explain how the relationship between voltage polarity and current direction relates to each component’s identity as either a source or a load.
Students often just want to memorize a procedure for determining answers to questions like these. Challenge your students to not only understand the procedure, but to also explain why it must be followed.
Something your students will come to realize in discussion is that there is more than one way to arrive at all the answers! While some of the steps will be common to all calculation strategies, other steps (near the end) leave room for creativity.
Complete the table of values for this circuit:
Discuss with your students what a good procedure might be for calculating the unknown values in this problem, and also how they might check their work.
In a parallel circuit, certain general rules may be stated with regard to quantities of voltage, current, resistance, and power. Express these rules, using your own words:
“In a parallel circuit, voltage . . .”
“In a parallel circuit, current . . .”
“In a parallel circuit, resistance . . .”
“In a parallel circuit, power . . .”
For each of these rules, explain why it is true.
“In a parallel circuit, voltage is equal across all components.”
“In a parallel circuit, currents add to equal the total.”
“In a parallel circuit, resistances diminish to equal the total.”
“In a parallel circuit, power dissipations add to equal the total.”
Rules of series and parallel circuits are very important for students to comprehend. However, a trend I have noticed in many students is the habit of memorizing rather than understanding these rules. Students will work hard to memorize the rules without really comprehending why the rules are true, and therefore often fail to recall or apply the rules properly.
An illustrative technique I have found very useful is to have students create their own example circuits in which to test these rules. Simple series and parallel circuits pose little challenge to construct, and therefore serve as excellent learning tools. What could be better, or more authoritative, than learning principles of circuits from real experiments? This is known as primary research, and it constitutes the foundation of scientific inquiry. The greatest problem you will have as an instructor is encouraging your students to take the initiative to build these demonstration circuits on their own, because they are so used to having teachers simply tell them how things work. This is a shame, and it reflects poorly on the state of modern education.
What will happen in this circuit as the switches are sequentially turned on, starting with switch number 1 and ending with switch number 3?
Describe how the successive closure of these three switches will impact:
I won’t explain what happens when each of the switches is closed, but I will describe the effects of the first switch closing:
As the first switch (SW1) is closed, the voltage across resistor R1 will increase to full battery voltage, while the voltages across the remaining resistors will remain unchanged from their previous values. The current through resistor R1 will increase from zero to whatever value is predicted by Ohm’s Law (full battery voltage divided by that resistor’s resistance), and the current through the remaining resistors will remain unchanged from their previous values. The amount of current drawn from the battery will increase. Overall, the battery “sees” less total resistance than before.
One problem I’ve encountered while teaching the “laws” of parallel circuits is that some students mistakenly think the rule of “all voltages in a parallel circuit being the same” means that the amount of voltage in a parallel circuit is fixed over time and cannot change. The root of this misunderstanding is memorization rather than comprehension: students memorize the rule “all voltages are the same” and think this means the voltages must remain the same before and after any change is made to the circuit. I’ve actually had students complain to me, saying, “But you told us all voltages are the same in a parallel circuit!”, as though it were my job to decree perfect and universal Laws which would require no critical thinking on the part of the student. But I digress . . .
This question challenges students’ comprehension of parallel circuit behavior by asking what happens after a change is made to the circuit. The purpose of the switches is to “add” resistors from the circuit, one at a time, without actually having to insert new components.
The circuit shown here is commonly referred to as a current divider. Calculate the voltage dropped across each resistor, the current drawn by each resistor, and the total amount of electrical resistance ßeen” by the 9-volt battery:
Can you think of any practical applications for a circuit such as this?
How much current is drawn from the battery in this circuit? How does this figure relate to the individual resistor currents, and to the total resistance value?
Some students may find the diagram hard to follow, and so they will find the task of analysis helped by drawing an equivalent schematic diagram for this circuit, with all terminal points labeled. I recommend you not suggest this solution immediately, but rather challenge your students to think of problem-solving techniques on their own. Surely, someone in the class will have thought of doing this, and the impact of such a suggestion coming from a peer is greater than if it came from you, the instructor.
Be sure to ask your students this question: “Why is this type of circuit commonly called a current divider?”
There is a simple equation that gives the equivalent resistance of two resistances connected in parallel. Write this equation.
Secondly, apply this two-resistance equation to the solution for total resistance in this three-resistor network:
No, this is not a “trick” question! There is a way to apply a two-resistance equation to solve for three resistances connected in parallel.
Rtotal = 25 Ω
In case you are still unsure of how to apply the “two-resistance” parallel equation to this network, I’ll give you a hint: this equation gives the equivalent resistance of two parallel-connected resistors. Examine this modified version of the original schematic diagram:
And who said technological work never involves creativity? This question challenges students to apply an equation to a problem that it is not ideally suited for. The basic principle used in the solution of the problem is very practical. It involves the substitution of an equivalent component value in place of multiple components, which is a problem-solving technique widely applied in electrical network analysis, as well as other forms of mathematical analysis.
Suppose you needed a resistance equal to precisely 235 Ω for the construction of a precision electrical meter circuit. The only resistors available to you are two 1 kΩ resistors, one 500 Ω resistor, and a rheostat variable between 600 and 1000 ohms. Design a parallel resistor network using any combination of these components that will yield a total resistance of 235 Ω. If you use the rheostat in your design, specify its resistance setting.
This problem is an exercise in estimation, and algebraic equation manipulation. Estimation will reveal which resistors should be combined together, and algebraic manipulation will give the exact values needed.
Draw the connecting wires on this terminal strip so that the three light bulbs are wired in parallel with each other and with the battery.
One of the more difficult visualization tasks for new students of electronics is translating schematic diagrams to physical layouts, and visa-versa. This, sadly, is a skill that I don’t see emphasized nearly enough in most basic electronics curricula. It seems the majority of class time is spent mathematically analyzing useless resistor networks, and not enough time is invested building students’ spatial relations skills.
While series connections are very easy to visualize on terminal strips, parallel connections are more difficult. Work with your students through this question helping those who lack the innate spatial relations ability to see the solution quickly.
A “trick” I often use to help students build this skill is to have them first draw a nice, clean schematic diagram. Then they over-trace each wire in the diagram as they draw it in the pictorial diagram. In this way, they make sure not to overlook connections in the pictorial diagram.
Choose two resistor values such that one resistor passes 25% of the total current, while the other resistor passes 75% of the total current:
There are many combinations of resistor values that will satisfy these criteria.
This is a fine example of a question with multiple correct answers. No matter how many unique combinations students invent, they may all be verified by a few simple Ohm’s Law calculations.
by Jake Hertz
by Duane Benson
by Jake Hertz
